Can't find in search: '93 Hatch and '89 CRX suspension compatability.
Old 08-16-2004, 09:32 AM
Another Drew's Avatar
Default Can't find in search: '93 Hatch and '89 CRX suspension compatability.
I've tried searching but I can't seem to find it.
I want to move any suspension components on my '89 CRX over to my '93 DX hatch.
Can I move any over? My primary concern is to move the rear trailing arm and then any other parts too.
If you know the answer or particular search terms to use, that would be great.
Thanks!
Old 08-16-2004, 09:33 AM
Spade's Avatar
Default Re: Can't find in search: '93 Hatch and '89 CRX suspension compatability. (Another Drew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Another Drew &raquo;</TD></TR><TR><TD CLASS="quote">
Can I move any over? </TD></TR></TABLE>
Nope.
Old 08-16-2004, 09:36 AM
Run Hatch's Avatar
Default Re: Can't find in search: '93 Hatch and '89 CRX suspension compatability. (Spade)
For a 92-00 civic you should use the 94-01 integra or the ex or si civic's brakes. Good Luck.
Old 08-16-2004, 09:45 AM
Default Re: Can't find in search: '93 Hatch and '89 CRX suspension compatability. (Run Hatch)
I don't care about the brakes. I have brand new oem bushings on every suspension piece on my crx. It's those suspension pieces that I want to put on my '93 DX hatch. I'll keep the brakes on the hatch, I just want new bushings on the hatch.
Old 08-16-2004, 02:08 PM
n1div's Avatar
I just tried this and can tell you from first hand experience:
Front shocks are different diameters on the shock body so they use different forks.
Rear shocks can work if you move the entire suspension over(shock,spring, top hat).
Strut hats are different since the eg springs are larger diameter.
You can reuse the strut hats if you change out the rubber liner.
9THREECIVIC
12-15-2003 08:01 PM
I8ayellowcrayon
09-07-2003 11:20 AM
ANGELL
04-30-2003 03:33 AM
EF-9SiR
01-13-2003 05:09 PM
Quick Reply: Can't find in search: '93 Hatch and '89 CRX suspension compatability.
