cant figure out why my car leaks oil
my car has been leaking oil from the head, the car does not smoke and their was no oil in the antifreeze. it was just leaking. so i ended up taking the car apart and found that the gasket was good, the head is flat and so is the block(i checked with a straight edge) and the guy at the machine shop said everything looks good. the leak was from by the timing belt. before i took everything off i check if the head was torqued right and it was.
i got a new head gasket, valve cover gasket and new cam seals, i will put everything back on soon.
