Can you use the oem main relay for a kill switch?
Hey i was looking at the schmatics for my hatch and it seems that i can tap into a wire that keeps power going to the fuel pump and not use a extra relay? Is this possible and what are the pros and cons of this?
Re: Can you use the oem main relay for a kill switch? (spencedogg)
yeah its effective. couldnt tell you how i know, or else id have to kill ya
the benefit is that you can tap into the line closer to the dash.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spencedogg »</TD></TR><TR><TD CLASS="quote">more thoughts on this</TD></TR></TABLE>
agreed.
does anyone have a pinout of the stock main relay? thanks.
agreed.
Ok i want to use the yellow and green wire that goes to the fuel pump with the main relay if someone can look at the wiring for a eg and tell me that this will work that would be nice
Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX »</TD></TR><TR><TD CLASS="quote">CHEAP KILL SWITCH:
Pop out your main relay and put it in your pocket. Works every time.</TD></TR></TABLE>
thats exactly what i did........only way your gonnna start the car is if you have
one on you.
one on you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spencedogg »</TD></TR><TR><TD CLASS="quote">Hey i was looking at the schmatics for my hatch and it seems that i can tap into a wire that keeps power going to the fuel pump and not use a extra relay? Is this possible and what are the pros and cons of this?</TD></TR></TABLE>
Yes,
Pros, don't tell anyone about it
Cons, do it while you disconnect the battery and soldier everything.
-Bert
Yes,
-Bert
