can you put D16 camshaft in D15?
i bought a D16 camshaft for my D15 cause the shop in st L said they are the same but when i got done installing it and tried to start it all that happend was a whining sound, it is turning but not starting. Is something to tight or too loose. i am taking to a shop about 10 in the morning on tuesday if i cant find out what is wrong. if you have ant suggestions let me know. thanks
Re: can you put D16 camshaft in D15? (charjacq)
The cam journals could be binding as this is not a stock cam.
Did you lube the cam w/ assembly lube before starting the car ?
Re: can you put D16 camshaft in D15? (X2BOARD)
did you make sure all the timing marks were lined up correctly when you put it in, and check the timing after installing the cam
Re: can you put D16 camshaft in D15? (SOHCwarrior)
what about the vtec lobes? the d15 doesnt have vtec...
i would think if it fit, there would be mad lumpy idle.
krazy
krazy
Re: can you put D16 camshaft in D15? (nema741)
swapping cams:
d16z6 <=>d16y8<=>JDM d15b sohc vtec (VTi) = interchange but require -+4.5 deg
d15b7<=>d16a6<=>zc sohc<=>d15b# (non-vtec 16v)
basically you need to keep it within the same type of head, there are 4 kinds of SOHC heads:
-16 valve non-vtec (88-91 Si d16a6, DX, LX)
-8 valve non-vtec (CX, HF)
-16 valve sohc vtec-e (HX, VX)
-16 valve sohc vtec (92-5 Si, EX)
honda cams which really don't or can't be interchanged due difference in valve train =d15z1 or d15b sohc vtec-e (ETi), HX d16y5, d15b8 (8 valve)<=>d15b2
Re: can you put D16 camshaft in D15? (eg6ajk)
ok the cam chaft was for a 88 91 crx si 1.5 non vtech. I did get it working the lifters just had to be adjusted to a completly different setting. I still have to get it tuned though. It is running but it is a little slower than it was before. and sounds just a little rough. so i just need to play with the timing and the adjustments on the cam gear. After this is up and running i am done with this stupid engine and saving up for a B18. I still have a Focuz intake manifold for a B16 for sale also. only used for about 3 days.
Cyphear
06-05-2007 04:38 PM
excivicboy96
10
01-10-2007 11:03 AM
