Can you identify these 3 plugs?
Can anyone identify these 3 plugs, all 3 are from a EG Si (D16Z6) harness
Right side: Green w/ white stripe & Red w/ yellow stripe
Center: Green w/ white stripe & Red w/ white stripe
Left: Solid red & Yellow w/ black stripe
Thanks for any help...
Re: Can you identify these 3 plugs?
Right side: Green w/ white stripe & Red w/ yellow stripe ** intake Air Temp Sensor located in the intake plenum or on the third runner from the Throttle body
Center: Green w/ white stripe & Red w/ white stripe ** Engine Coolant Temp sensor located on the head i believe**
Left: Solid red & Yellow w/ black stripe ** Evap Purge solenoid valve its a black plastic piece bolted to the back/top of the intake and it has a little round hat on it.
looks like someone is doing a wire tuck....
wuggiewuggie
Honda S2000
10-25-2006 07:16 AM
