Can you figure out whats wrong with my 94 Ex?
94 Honda Civic EX 1.6-
So i posted once before and had alot of help but..to my dismay my car still will NOT start.
I have replaced and yes its OEM:
Distributor/Wires/Plugs/Rotor/Distributor Cap
Head Gasket
Main Relay
Map Sensor
Fuel Filter
It cranks but doesn't get that EXTRA to fire up. It had a bad head gasket so we replaced it, we did a tune up on it and got the oil changed. We put an injector cleaner in it and for a whole day it ran like it was brand new again. I was almost home when something clicked and my car died and it hasn't started since.
I honestly cant figure out what the problem is now, everything i tried has not worked.
I had a mechanic tell me that it could be my fuel pump even though i can hear it prime before i try starting it, could it that its getting fuel just not enough to start it?
some PLEASE help me figure out whats wrong with my car.
Head Gasket
Main Relay
Map Sensor
Fuel Filter
Re: Can you figure out whats wrong with my 94 Ex?
Check the ignition fuse under the dash its a 15 fuse and controls distributor spark. Let me know if this works
Have someone help you. Have them turn the ignition while you pull one of the sprk plug wires out and see if each of them spark.
fastlimegreencivic
03-23-2013 05:34 PM
sidewayz
04-29-2003 11:35 AM
