Can You Change Total Mileage on an SI Gauge Cluster?
Hi
I remember surfing the net and reading that it was possible to change the total mileage on a cluster or swap it out with the one I am currently using. Do you guys know if this is possible? Or was I daydreaming...
If so, how?
Thanks!
If so, how?
Thanks!
Re: Can You Change Total Mileage on an SI Gauge Cluster? (dwnthehatch)
Here's a link to a write-up I did on how to swap odometers between clusters:
https://honda-tech.com/zerothread?id=276819
QE B96v6
QE B96v6
Re: Can You Change Total Mileage on an SI Gauge Cluster? (Quasi-Evil B96v6)
if u push the numbers real hard with a nail or knife they move.. i did this too my old hatch alot..
mike
mike
Re: Can You Change Total Mileage on an SI Gauge Cluster? (civicracer1993)
If I push it hard, I can shift the numbers? to the desired digits? And it will run and change smooth?
Location: Why so you can pretend like youre interested, FL/OK
Re: Can You Change Total Mileage on an SI Gauge Cluster? (JDMekCIVIC81)
Re: Can You Change Total Mileage on an SI Gauge Cluster? (SHAUNTS99)
I spent a couple hours fondling and staring at my 99 DX cluster to see how you can change the mileage. and I figured out how to do it perfectly.
It's rather easy.. you just have to line certain things back up.
If someone posts a pic of a cluster, I'll show you how.
Re: Can You Change Total Mileage on an SI Gauge Cluster? (I can't believe this ****)
I spent a couple hours fondling[QUOTE/]
And to the cluster question you can roll back
the numbers if you take out the odomiter peice.
Re: Can You Change Total Mileage on an SI Gauge Cluster? (98CTRCoupe)
Isn't this illegal? I know you can take it to some place and get it documented so it's legal, but what place... the DMV? Also, with a swap... do you change the numbers to the mileage of the motor or the mileage of the chasis? Thanks
Scott
Scott
Okay, now show us...
Re: Can You Change Total Mileage on an SI Gauge Cluster? (SlippylesKB)
No, he needs a picture of the back side of the actual odometer, not the backside of the cluster. I took my cluster apart and it looked far too complicated, a lot of small parts and gears. I just recorded the milage on my chassis, milage on the cluster, and milage on the engine swap.
some tips:
you will need very thin tweezers/needles...and some quiet hands...(serious)
when you start to roll back the #'s the gridlines should line up before putting the pieces together for your cluster...or else the numbers will not line up....trial and error basically
Re: Can You Change Total Mileage on an SI Gauge Cluster? (EKryder)
ok here ya go
take out the 4 screw here after you removed the cover, lense and all the stuff from the front of hte cluster. the speedo will now drop out
you now have 2 choices. 1 take your original speedo and put it in the new cluster or 2 roll you milage back. i prefer option 1
notice the gears?
the black ones controll your milage. you can sit there will a drill and a philips head bit for hours on end and roll the milage back useing theres gears. now to cover my ***. this is just educations information. not intended for use. i'm not liable
notice the gears?
when I got my si cluster I called up a honda dealership and asked where they took spedo's to get recalibrated. whet to this shop and they looked at my car with the original spedo in it and wrote down the mileage. 2 hours and 20 bucks later I had my cluster back with the mileage that my cluster showed when I went to the shop to drop it off. the guy said the dmv didn't care if the cluster was off a couple miles. For those that say I should have done it myself look at it like this. I have proof of what was done and a recipt to show for it.
Re: Can You Change Total Mileage on an SI Gauge Cluster? (snail)
How can I take the original mileage speedo and put it into the new one?
Pictures how to?
Thanks!
Pictures how to?
Thanks!
Re: Can You Change Total Mileage on an SI Gauge Cluster? (Kid1320)
Good Post Question though, doesnt your ECU record how many KMS or Miles you have on the engine? Stock I mean? For example if you take the car to the dealership can they "plug it in" and find out the milage?
I would be really careful with the newer cars because i been told that they have 2 odometer in a car now. one in the cluster and another in the car that is digital. i was told by this at a dealer lot in buena park. so if you have a 2002 and up be careful. anyways, how much **** can i be in if i got caught rolling back my miles in my eg?
