Can someone tell me about the SRS light on the dash?
I have a '97 Civic EX, the SRS light on the control panel near the odometer is lit up. Could someone please tell me what would cause it to come on?
Does the SRS have anything to do with the airbag?
Location: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Re: Can someone tell me about the SRS light on the dash? (Greg S)
SRS = Supplemental Restraint System
It is supposed to supplement your seat belt, aka airbags...
The SRS light can go on for many reason, including but not limited to:
Loose connector in the SRS system. A faulty or discharged airbag. Bad SRS controller. If you don't know what your doing, or if you don't have a Factory Service Manual from Honda, I wouldn't **** with it. Take it to the dealer. Or open up the bottom of the steering wheel (there will be a little cover) disconnect the yellow connector and install the red short connector that is in there. (This will keep the drivers airbag from deploying at all) Then pull the gauges and remove the bulb. (So no one will know there is an SRS problem)
Modified by HondaFanatic708 at 10:43 PM 12/3/2004
Re: Can someone tell me about the SRS light on the dash? (HondaFanatic708)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaFanatic708 »</TD></TR><TR><TD CLASS="quote">SRS = Supplemental Restraint System
Modified by HondaFanatic708 at 10:43 PM 12/3/2004</TD></TR></TABLE>
I think im gonna have to look into that, I recently pulled my bulb for the SRS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greg S »</TD></TR><TR><TD CLASS="quote">Could someone please tell me what would cause it to come on</TD></TR></TABLE>
My problem was the cable reel in the steering wheel
Check to see if your horn works....that will let you know if its the reel
If the horn works it could be any of the problems HondaFanatic708 listed above
Re: Can someone tell me about the SRS light on the dash? (EGinNY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGinNY »</TD></TR><TR><TD CLASS="quote">
If the horn works it could be any of the problems HondaFanatic708 listed above</TD></TR></TABLE> There is also the same little red connector for the passanger side if you don't like your friends, lol. But if you EVER disconnect an airbag for any reason make sure to install the red short connector. Without it the airbag may deploy causing accidental death or serious injury. If you install the red clip in a fully functional SRS system the light will stay on, thats why I said pull the bulb cause that **** can be annoying. It could be other issues as well, Thanks for the props man...
lv6l
Honda Civic (2001 - 2005)
10-27-2006 08:13 PM
Nuts
07-02-2002 10:59 AM
