Can someone take a picture of there thermostat ground?
Just trying to track down all my wiring woes and could use a bit of help. Can anyone take a picture of their thermostat ground and where it it connects to the harness? EG or EK shouldn't matter.
Thanks in advance.
Thanks in advance.
Re: Can someone take a picture of there thermostat ground? (FritzInTN)
I guess my question is this ground cable something that should be attached to the chassis or the wiring harness?
Thermostat ground grounds the engine wiring harness. Your car will most likely not start if you do not it in.
Re: Can someone take a picture of there thermostat ground? (turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer »</TD></TR><TR><TD CLASS="quote">Thermostat ground grounds the engine wiring harness. Your car will most likely not start if you do not it in.</TD></TR></TABLE>
Yeah I found that out the hardway ( https://honda-tech.com/zerothread?id=868200 ). Just wanted to confirm the proper place on the harness that attaches there before I go connecting wires.
sorry to bring up an old thread but can this ground be grounded anywhere? or must it specifically be grounded to the thermostat housing (the harness ground I mean).
Re: Can someone take a picture of there thermostat ground? (SkRiBLaH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkRiBLaH »</TD></TR><TR><TD CLASS="quote">its actually the grounds for the injectors.</TD></TR></TABLE>
And the ECU.
And the ECU.
Tippyman
04-11-2006 08:34 PM
streetracerof06
09-02-2005 07:16 AM
