Can someone show me a pic of coolant in your oil?
My car overheated again today after I thought I had fixed the problem 2 months ago.
Im about to change my oil and I want to know what to look for... for a headgasket leak. I have pretty much changed everything. Thanks |
if it dosent look like "chocolate milk" its fine
i dont have a pic. but all you need to look for if ur head gasket is leaking is look for a light brownish green on your dipstick....
https://i19.photobucket.com/albums/b.../watermark.jpg
headgasket leaks dont necessarily mean you will get coolant in your oil, although it is quite common. sometimes the coolant is burned up in the combustion chamber and slowly consumed from the radiator, but the oil will remain perfectly clean. generally your temp gauge will cycle from ultra hot to medium and then back to super hot again. you may also see disappearing coolant from the rad. when you're not leaking any. |
Okay where here is the issue.
1. It overheated when I first bought the car a year ago. 83k 2. Didnt drive the car very much the first 6 months only maybe 5k or so, but it didnt overheat very often, only occasionally and NEVER on the highway, only in big traffic. 3. Changed thermo with honda one, thought it worked, it didnt. 4. changed the radiator with a bigger one,(brand new) didnt work. 5. I thought I bled the system wrong, I have bled it 5+ times, and about 2 months ago I did and it had not overheated for 2 months, it just now did again. And I remember the coolant resivour was full, it is now empty. 6. I have owned the car for about 8k or so miles. It has to be a head gasket now because their is nothing else to do.(which sucks). |
Im pretty sure I have dissapearing coolant in my rad, and I know im not leaking any. So I guess its confirmed its a head gasket.
Originally Posted by D16SiHatch
(Post 36489958)
But what i do notice is disappearing coolant from my radiator, and a nice black film from traces of oil on the inside of my coolant reservoir. Not trying to steal thread or anything but we possibly have the same problem. |
check ur hoses. the heater hose is the most common of all to crack. and there hidden under the dizzy.
Originally Posted by mizzoEG
(Post 36490096)
this makes sense, my 94 hatch d15b7 has an overheating problem also. the temp gauge likes to go 2/3 high when i'm in stop-and-go traffic or idleing. i've looked at and changed my oil countless times and didn't see noticable traces of coolant in it.
Originally Posted by fryguy190
(Post 36490113)
have u replaced the radiator cap
Originally Posted by batallic
(Post 36490539)
have you checked the fan to see if it is turning on at the right time..you say it overheats in traffic so maybe it has something to do with your fan
Originally Posted by vano
(Post 36491442)
(Post 36491442)
Changed the Fan Relay Replace the Rad Cap x2 Bled/Flushed the Coolant System x856254 Changed the Thermostat Changed the Thermoswitch Changed the TempSensor Radiator is practically New & 100% NO COOLANT LEAKS i feel like i've done everything and the only place left is my headgasket, and since i've got oil build-up in my coolant reservoir i think that speaks for itself. krisfnbs: have you found any traces of oil in you're coolant reservoir? |
(Post 36493713)
the problem doesn't have to do with the fan because it still turns on. the problem to understand is that the engine likes to overheat before the fan actually kicks on. i've done the following and it didn't fix anything:
Changed the Fan Relay Replace the Rad Cap x2 Bled/Flushed the Coolant System x856254 Changed the Thermostat Changed the Thermoswitch Changed the TempSensor Radiator is practically New & 100% NO COOLANT LEAKS i feel like i've done everything and the only place left is my headgasket, and since i've got oil build-up in my coolant reservoir i think that speaks for itself. krisfnbs: have you found any traces of oil in you're coolant reservoir? I have a friend that can help me do the job thank god, but Its going to take forever and its a pain in the ass. |
I wouldn't overlook the radiator cap. Give a new one a try.
Originally Posted by Dann6968
(Post 36497018)
You need to try pressure testing the coolant system with a pump and a gauge designed specially for this, they are available in parts stores. Do it cold and see if it holds pressure overnight.
You might also try running the engine with the cap off and see if there is good water circulation or air bubbles indicationg a leaking head gasket. This will also purge any air that may be locked in the system somewhere. Again, new or not, the thermostat istself may be suspect too. Pop a thermometer in the top of the radiator and check the temperature and compare it to the thermostat type and aslo to check the dash gauge for accuracy. The water pump itself may be suspect as the impellers can rust on high milage cars and not pump as well as they should. The cooling fan thermo/switch may be suspect or intermittant or may not be turning on at the correct temperature, which should be well before the temp guage reaches over 1/2 way, or a few degrees over the opperating temperature of the thermostat, again, compare with a known good thermometer, allow 5/10 degrees either way for an acceptable error. Finally everyones favourite when installing a new radiator, did you remove all the plastic shipping plugs from the hose connections. Check the pressure cap is the right pressure and type for this engine. New or not, thay can be faluty. Check the suction tube in the overflow bottle didn't fall of. How much coolant are you loosing ? If you're burning it up in the cyls because of a leaking gasket you should be able to smell the antifreeze (a sweet smell) and aslo see white smoke/steam in the exhaust. BTW, coolant with the correct %age of antifreeze and say 12psi won't boil till well over 240 degrees F Get back to us with your findings after you have tried all this. |
Common Signs of a Bad Headgasket:
Overheating White Smoke out of your exhaust That white smoke also smelling sweet (burnt glycol) Milky white residue underneat your oil cap Chocolate Milk looking oil Oil buildup in coolant Bad compression in a cylinder Slow coolant consumption but no leaks, etc. Erratic coolant temp changes. Sounds like you've got a bad headgasket sir. I know all about these, as I used to own an Mkiii supra (every mkiii gets one) |
Originally Posted by itsmejto
(Post 36499351)
