can i use this tps on my b16 head ??
ok this question may sound dumb, but my tps sensor on my b16 intake its broken, i also have a d16y8 intake with tps, is it possible to use the d16 tps on my b16 tb ?
Re: can i use this tps on my b16 head ??
none of the tps were designed to be unbolted but ive been reading that people can cut a slit on the bolt head and use a flat head screw driver to remove them, but youll have to recalibrate after install of new one
i have the omni power tps i snapped the old one of the treaded bolts in so i wud never have to deal with not bieng able to take it off
there is write up dont remember off the top of head but basically you need a multimeter and measure the voltage of signal wire (dont remember which color) at closed throttle volts should be i think .5 and at wot volts should be 4.5 there is screw on tps for adjusting volts.
Crazy Honda Guy
All TPS sensors can be easily removed. On jdm motors, they are a phillips screw, on a usdm looks like a rivit, but it is not! Simply dremal a notch in it, and it will screw right out!
it will be easier to use your d-series tb until you can find a complete b-series one. it may sound dumb, but i had to do it for a few days because i snapped the tps on the b16 going in. you wont have the top end power out of a matching tb, but it WILL work.
Crazy Honda Guy
All you had to do was swap the tps from the d series TB the the B
too much work for my limited knowledge
it will work fine, im actually running a obd1 ls tb on my b16 and i noticed a huge gain in topend vs the measly d series
Crazy Honda Guy
