idle drops
Old 08-11-2006, 06:21 AM
u_gnit's Avatar
Default idle drops
not to sure if it might be a charging system problem, or mechanical with the motor, but when the idle drops, so does the power (voltage also drops).......can anyone help me out?
Old 08-11-2006, 06:29 AM
poison's Avatar
Default Re: idle drops (u_gnit)
Is this while normal driving after a while, while warming up?
details details..
Old 08-11-2006, 06:44 AM
u_gnit's Avatar
Default Re: idle drops (poison)
both, when i start it to warm it up, the idle sometimes stays low, others while driving while at a stoplight or when the car comes to a stop. it's weird cause i notice it happens sometimes when i step on the brakes coming to a stop the car does it too, that's why i'm not sure if it could also be a charging system problem!
Old 08-11-2006, 09:10 AM
miahmouse's Avatar
If the idle fluctuates when you hit the brakes it's the booster gone bad... (leaking)
could also be the IACV sticking and the brakes thing is just a coincidence... disconnect the IACV... the idle should drop way down/nearly stall... when you plug it back in you should hear a click...
A voltage dip could also cause the idle to drop and the idle dropping will most certainly cause a dip in voltage.
start the car and check the voltage, after a decent drive when everything is warm check the voltage again. if it's significantly lower the alternator may be on it's way out...
Old 08-11-2006, 09:21 AM
u_gnit's Avatar
Default Re: idle drops (miahmouse)
thanks a lot. i appreciated. makes a lot of sense. i'm bout to go check it out!
dc4b20
22
12-03-2012 09:54 PM
92_JDM
Engine Management and Tuning
08-12-2010 03:23 PM
bb4 jdm lude
03-12-2008 09:25 AM
efyou
04-18-2007 06:00 PM
tylerdurden
04-11-2003 05:53 PM
Quick Reply: idle drops
