can a b15d7 become DOHN vtec ? OR JUST SOHN VTEC?
Re: can a b15d7 become DOHN vtec ? OR JUST SOHN VTEC? (ANDRESDELSOL)
You've got a little dyslexia going on in your post, but I think I know what you mean. Though some ZC D series are DOHCs, as far as I've seen, mini-me's have only been SOHC VTEC.
D heads only fit on D blocks.
B heads only fit on B blocks
......catch my drift here?
also please lay off the crack and read thoroughly what you are typing. Your posts are almost hard to read/comprhend
Re: can a b15d7 become DOHN vtec ? OR JUST SOHN VTEC? (broketuner-Sol_Si)
thanks for the info
now that i know that do u think could be possible swap an dohc head on my d15b7 block... this engine is sohc!!
You want a mainstream DOHC? Get a B series. Go full swap. Get a ZC DOHC if you want, but you probably won't like it.
Re: can a b15d7 become DOHN vtec ? OR JUST SOHN VTEC? (BlackoutVTi)
what i want is to do a mini me in my single cam>>.... ihowever if exist any possibility that i would swap a doble cam in my original engine i would like to explore that other way... now my question to you is do i have any chance to do that?? or i bettes steal with my single cam minime?
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ANDRESDELSOL »</TD></TR><TR><TD CLASS="quote">what i want is to do a mini me in my single cam>>.... ihowever if exist any possibility that i would swap a doble cam in my original engine i would like to explore that other way... now my question to you is do i have any chance to do that?? or i bettes steal with my single cam minime?
Please, please learn english, i can't even understand your last post. Yes you can swap a SOHC vtec head on a SOHC non-vtec block, this is a mini-me. No you cannot swap a DOHC head on a SOHC block. Yes you can swap in an entire DOHC engine, generally you also need the matching transmission, axles mounts, shift linkage ecu, etc. You can swap in an OBD1 DOHC ZC and not have to change anything but the ECU, even thats somewhat optional. That engine is fairly uncommon though and has essentially no aftermarket support, for replacement parts the list of vehicles to get replacement parts from reads like a grocery list, and some things such as the distributor were never available in north america at all.
Re: can a b15d7 become DOHN vtec ? OR JUST SOHN VTEC? (94EG8)
thanks ... and for my nexts post's ill try to be so clear... so im goign to do the mini me for a single cam.. what do i need to get it done/? and working properly?
read and for Christ sakes do a search, deucate your self, also if you don't have any experience with cars save your self the headache and pay someone who knows what they are doing!!! do it right the first time!
Former Moderator
Let's first establish this:
Exactly what engine do you have now?
Is it a D15B7?
Is it a D15B7?
