Camber Kit???
Camber Kit???
I recently bought a 99 Civic Si with aftermarket springs/shocks. The front wheels butterfly pretty badly, and I'd like to fix that before I buy new tires and ruin them again... My local preformance shop offers a kit for $180 which seems a little expensive. I've seen alot of kits on ebay for ALOT LESS and my question is, is there a difference in quality and what should i look for? (brand names?)
Thanks.
Thanks.
Re: Camber Kit??? (GapxGuy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GapxGuy »</TD></TR><TR><TD CLASS="quote">the rear you can DIY with washers.</TD></TR></TABLE>
its true and its a good idea
1 Post
yay you could cut your springs too.... no offence but sticking washers in the back just seems like the half assed cheap way to do it.... much like cutting springs to lower your car. With all the money most people here are dumping into their cars why not just spend a little more to do **** right? Experience will usually show that taking the cheap road will usually end up with cheap results. Something good to keep in mind when spending money on anything.
Re: Camber Kit??? (civickidd99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickidd99 »</TD></TR><TR><TD CLASS="quote">for people that aren't going to adjust the rear suspension, the washers do just fine.</TD></TR></TABLE>
I agree
I agree
Re: Camber Kit??? (fire7882)
Skunk2 it is, and make sure that you are getting the newest production of the Skunk2 camber kit. I believe the old kit had problems w/ premature wear of the ball joint.
Re: Camber Kit??? (Dj Villain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dj Villain »</TD></TR><TR><TD CLASS="quote">how hard is it to install camber kits??</TD></TR></TABLE>
It's easy... if you know what you're doing.
Re: Camber Kit??? (Spoon)
If you call the washer a "shim" you will desribe what is used at the FACTORY and by alignment shops to adjust all aspects of suspension geometry as described by the manufacturer on lots of vehicles.
Cliff Notes.
Washers work great in the rear because the washers work great.
Cliff Notes.
Re: Camber Kit??? (vtecvoodoo)
for all of you who use washers for the rear....what size washers do you all use??? i might just use washers in the rear and fix the front later. would that cause any problems??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dj Villain »</TD></TR><TR><TD CLASS="quote">for all of you who use washers for the rear....what size washers do you all use??? i might just use washers in the rear and fix the front later. would that cause any problems??</TD></TR></TABLE>
here you go man..
http://home.earthlink.net/~civ....html
hope that helps.
I did it to mine.. works like a charm.
here you go man..
hope that helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon »</TD></TR><TR><TD CLASS="quote">
here you go man..
hope that helps.
I did it to mine.. works like a charm. </TD></TR></TABLE>
thanks alot Spoon, that helps alot...now im gonna go get some of those bolts and washers at work.
here you go man..
hope that helps.
i was wonderin if a camber kit could fix MY problem . . i recently got 17z on my car(goahed n call me a ricer hehe) w/ 205-40-17 tires. As of right now, there is no wheel well gap what so ever so the tires rub when i turn(front AND back). Would me getting a camber kit take care of this problem ??
Re: (makaveli284)
If you tires rub now, a camber kit will make them rub worse assuming you want to set your camber closer to zero then it is now.
Re: (tonyXcom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonyXcom »</TD></TR><TR><TD CLASS="quote">If you tires rub now, a camber kit will make them rub worse assuming you want to set your camber closer to zero then it is now.</TD></TR></TABLE>
negative camber might help though
rZm
Suspension & Brakes
01-20-2010 11:51 AM
djtony5
12-30-2003 05:04 PM
willymac22
11
12-05-2003 10:18 AM
