cam install question
I was told that you can install an aftermarket camshaft into a motor and not have to adjust the valve lash that the manufacturer suggested is this true or no?
Re: cam install question (simplypinoyy)
i suggest reading prostreetonline.com write up on cam install..... check the how to's if your looking for cam i have ek chassis com cams 105300 for sale for 220shipped in the us..
Re: cam install question (Tommytom83)
thats great but i have an eg and I already have the zex 59300 installed... the main question is if it is really important to adjust the valve lash or not
Re: cam install question (Echo7847)
you can more then likely get away with using the stock valve lash specs with that cam. my old skunk2 cam said to adjust the valves to the stock lash settings. its definately good to do tho. i would recommend doing it
Tyson
12-18-2007 10:49 AM
HondaFanatic708
15
06-03-2004 04:36 AM
Aron Parsons
02-04-2002 06:38 PM
