Cam Help !!!!!!!!!!!!!!!!
ok A guy gave me a set of brand new cams with my B16 Delsol(Stock B16). he said they were Stage 2 CROWER cams. So I put them in they all lined up and looked fine then put it in time. then I went to put the distributor slot on the cam isnt lining up with the distributor. what could they be then if the fit but that doesnt line up????
Re: Cam Help !!!!!!!!!!!!!!!!
ok u line the dizzy tooth to fit and it seem the slot doesn't line up with the dizzy's tooth. i even took the valve corver off to check and it seem the tooth slot is off like 2 mm
EK9
That's what I was kind of thinking. I thought he might of just got them to sit in there or something. I still don't get why the dizzy key wouldn't line up with the cam? Unless op is explaining it wrong or isn't turning the key to where it will line up
no u hit it right on the nose. im not at home rtight now so i cant take pics atm
EKsnatchhatch
10-11-2009 11:10 PM
