calling all eg owners with single cammers
Old 08-23-2008, 06:20 PM
civiccoupe94's Avatar
Default calling all eg owners with single cammers
how fast is the engine spinning at 60/65/70/75 mph on your dx/lx tranny or ex tranny 5 speed manual?
mines is at 2,500 rpm at 60mph, i'm not sure if i have a ex or dx transmission. the previous owner said he changed the tranny, but didnt know which one was on. i'm hoping that its a dx tranny, since i want to save gas these days while on the highway.
92-95 civics
Old 08-23-2008, 06:26 PM
Cowtit's Avatar
before i did my swap i would run about 2500rpm at 65mph. that was a d15 non vtec motor with lx tranny. i swapped in a d16z6 (motor only, kept the lx tranny), not sure what my rpm's are, i'd have to check. but i went from 37mpg to 33mpg, its still worth it for me though becuase that d15 was horrible. couldn't maintain speed uphill on interstate and merging onto the freeway was just dangerous!
Old 08-23-2008, 09:44 PM
Paprika's Avatar
Default Re: (Cowtit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cowtit &raquo;</TD></TR><TR><TD CLASS="quote">before i did my swap i would run about 2500rpm at 65mph. that was a d15 non vtec motor with lx tranny. i swapped in a d16z6 (motor only, kept the lx tranny), not sure what my rpm's are, i'd have to check. but i went from 37mpg to 33mpg, its still worth it for me though becuase that d15 was horrible. couldn't maintain speed uphill on interstate and merging onto the freeway was just dangerous!</TD></TR></TABLE>
SOUNDS EXACTLY LIKE MY CAR!! :-p
Merging, however, i just rev it up. But nothing can really save me from long uphill climbs on the highway other than flooring it before i get to the hill and using the momentum to try to stay above 60 until reach the top!!
Old 08-24-2008, 06:40 AM
is it really that bad of an acceleration? i had my car for 4 years, i never minded the acceleration. i really dont need to race or anything like that, just use it as a DD, point a to b car that gets great gas mileage.
Paprike, whats your rpm's at 60, 70, etc?
Old 08-24-2008, 06:51 AM
nomoshing's Avatar
ahhh sounds like D engines
haha
Old 08-24-2008, 07:01 AM
SleepyHatchZ6's Avatar
i have the si tranny which im pretty sure is the same as the ex and at 70mph im at 3ki dont really know anything else thats my cruising speeds
Old 08-24-2008, 08:59 AM
SlaMMedB16's Avatar
Default Re: (SleepyHatchZ6)
i swapped in a z6 into my hatch, motor and tranny. Im at like 3-4k rpms from 60-80
Old 08-24-2008, 09:04 AM
supersteven's Avatar
I'm at like 3k at like ~75ish in my Del Sol S(DX tranny)
Old 08-24-2008, 09:17 AM
riceburnerryan's Avatar
im at like 3000 at 80, and i believe i have a DX tranny as well
Old 08-24-2008, 09:49 AM
sageuvagony's Avatar
you guys talking about 5th gears?
Old 08-24-2008, 09:52 AM
AddictedTo5's Avatar
Default Re: calling all eg owners with single cammers (civiccoupe94)
I've got an '92 LX and I'm just at 3,000 going 80. If that helps any.
Old 08-24-2008, 12:41 PM
hushypushy's Avatar
I have a 95 EX with 185/60R14's and 55mph = 2700RPM in 5th gear.
Modified by hushypushy at 1:50 PM 8/24/2008
Old 08-24-2008, 12:44 PM
JdelMsolG's Avatar
Default Re: (hushypushy)
it would help alittle if you would specify what gear you're talking about.
Old 08-24-2008, 12:53 PM
2004es2's Avatar
I have a y8 in my hatch and i cruise at 120km/h at like 3k rpm. I had a d15b7 before that and it was almost the same, the y8 has much better accelaration though.
Old 08-24-2008, 01:02 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccoupe94 &raquo;</TD></TR><TR><TD CLASS="quote">how fast is the engine spinning at 60/65/70/75 mph on your dx/lx tranny or ex tranny 5 speed manual?
92-95 civics</TD></TR></TABLE>
With a DX/LX trans:
60mph = 2450
65mph = 2655
70mph = 2860
75mph = 3065
With a EX trans:
60mph = 2645
65mph = 2865
70mph = 3090
75mph = 3310
(All values +/- .1mph)
Those are with the OEM tires, the OEM tach isn't really accurate enough to tell by that.
The largest difference in gearing is the second gear, that's where you'll find the most accurate.
EX:
@ 6500 RPM in 2nd you should be hitting about 54mph
DX/LX:
@ 6500 RPM in 2nd you should be hitting about 61mph
Since Honda tachs aren't really accurate worth of dick, you'll need to kinda combine those notes to figure it out, that way.
Old 08-24-2008, 01:05 PM
Syndacate's Avatar
Default Re: (JdelMsolG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdelMsolG &raquo;</TD></TR><TR><TD CLASS="quote">it would help alittle if you would specify what gear you're talking about. </TD></TR></TABLE>
He said he's doing 60mph @ 2500 RPM.
You know any OEM '92-'95 civic trans's that do 2500 RPM @ 60mph in a different gear than 5th?
Old 08-24-2008, 04:16 PM
JdelMsolG's Avatar
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
You know any OEM '92-'95 civic trans's that do 2500 RPM @ 60mph in a different gear than 5th?</TD></TR></TABLE>
haha, yeah i guess you have a point.
Old 08-25-2008, 06:58 AM
Default Re: calling all eg owners with single cammers (Syndacate)
With a DX/LX trans:
60mph = 2450
65mph = 2655
70mph = 2860
75mph = 3065
With a EX trans:
60mph = 2645
65mph = 2865
70mph = 3090
75mph = 3310
EX:
DX/LX:
Since Honda tachs aren't really accurate worth of dick, you'll need to kinda combine those notes to figure it out, that way.</TD></TR></TABLE>
thanks.. just what i needed. i think i have a ex tranny, but i will make sure on the highway
CRXREFIC
08-07-2009 10:19 AM
haitian1
13
02-17-2006 02:55 PM
Kyles ej1
08-19-2004 06:05 PM
gloryhog
14
01-15-2004 08:42 PM
S13 slide
09-06-2002 12:33 PM
Quick Reply: calling all eg owners with single cammers
