calculating hp?
calculating hp?
WHAT UP EVERYONE? I WAS JUST WONDERING IF THERE IS A SITE THAT CAN CALCULATE HOW MUCH HP MY CIVIC IS PUSHING. MY MODS ARE AS FOLLOW:
2 3/4 PIPING
DC HEADERS
TANABE EXHAUST
VENOM 400 PERFORMANCE CHIP
STAGE 2 CLUTCH
PORT AND POLISHED 3 ANGLE VALVE JOB
8.5 MM SPARK PLUG WIRES.
IF I ADD ALL OF THIS LIKE IT SAYS I SHOULD BE HITTING AROUND 165-170HP. HELP ME OUT PEOPLE
2 3/4 PIPING
DC HEADERS
TANABE EXHAUST
STAGE 2 CLUTCH
Re: calculating hp? (SOHC_MShue)
Someone might be able to give a guess if we knew what motor you have. Otherwise, go to the dyno as stated.
Also, don't write in all caps, ITS ANNOYING AS HELL.
No way you can get over maybe 120 on a D16 with just bolt ons and a little head work. Maybe with some major internal mods.
Re: calculating hp? (SIC_WIT_IT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIC_WIT_IT »</TD></TR><TR><TD CLASS="quote">IF I ADD ALL OF THIS LIKE IT SAYS I SHOULD BE HITTING AROUND 165-170HP.</TD></TR></TABLE>
wow sorry, but you're most likely WAY off. just to venture a guess i'd agree with others and say that, at the wheels, you're somewhere in the 120 range + or - 5. at the flywheel, it's usually around 15-20% more than the wheels so roughly 15-25hp more. but there are so many lurking variables when you consider this, the only way to know with any level of confidence is to see the dyno.
i don't know anything about that venom chip, so you could be pushing 500 for all i know.
i wasnt aware that civic's PUSH hp...im guessing your stage 2 clutch adds maybe 30hp alone ...and headers???...plural???...you got a v6 or v8 in that bad boy???
either dyno it or find somone with a similar set up and see what they are at for a rough guestimate.
ok then explain how am i keeping up with a ls integra? (and no it isn't the driver) and i have a single cam. and no i have one header that was a slip of the fingers.
Re: calculating hp? (FlatBrokeHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatBrokeHatch »</TD></TR><TR><TD CLASS="quote">i wasnt aware that civic's PUSH hp...im guessing your stage 2 clutch adds maybe 30hp alone ...and headers???...plural???...you got a v6 or v8 in that bad boy???
either dyno it or find somone with a similar set up and see what they are at for a rough guestimate.</TD></TR></TABLE>
i honestly hate when people go out of their way to sound so smart. no, a clutch
does not add power, but we all know that. and the whole header, headers thing,
i'm sick of people correcting that. it's not a big deal, you know what they mean.
trying to look like you know stuff makes you look like a tool.
BTW: SIC_WIT_IT, i've got an LS and i bet you can't keep up with me!
Risky Business
Re: (SIC_WIT_IT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIC_WIT_IT »</TD></TR><TR><TD CLASS="quote">ok then explain how am i keeping up with a ls integra? (and no it isn't the driver) and i have a single cam. and no i have one header that was a slip of the fingers.</TD></TR></TABLE>
LS integras run mid 15's...they aren't ungodly quick...
Moderator
IF I ADD ALL OF THIS LIKE IT SAYS I SHOULD BE HITTING AROUND 165-170HP. HELP ME OUT PEOPLE </TD></TR></TABLE>
no you won't!!
no you won't!!
needed to type it all in caps eh?....awesome....
youre probably only keeping up with the ls because of the clutch grabbing harder
go to a dyno, because otherwise Im going to have to say 40million whp
Re: calculating hp? (Djaric)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Djaric »</TD></TR><TR><TD CLASS="quote">No way you can get over maybe 120 on a D16 with just bolt ons and a little head work. Maybe with some major internal mods. </TD></TR></TABLE>
id venture to say that you are wrong my friend. there are numerous users on this board putting out a little above 120 whp in d16 sohc vtecs with just bolt ons.
- to the creator of this thread- imma say 120 or so hp. put a cam in that biatch and you could see close to 130 or so cause of your headwork. ps. ditch that 2 3/4 piping and get 2 1/4, you need the backpressure
Re: calculating hp? (B18Bcivic93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Bcivic93 »</TD></TR><TR><TD CLASS="quote">
BTW: SIC_WIT_IT, i've got an LS and i bet you can't keep up with me! </TD></TR></TABLE>
ya no joke...we all know its header so correct them in a way that helps them learn, but dont do it so you sound like a smart ***..this is the same thing with vtec..we all know its vtec, but dont be all smart *** about it when ppl spell it vtech...
Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno V
Re: calculating hp? (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg »</TD></TR><TR><TD CLASS="quote">
- to the creator of this thread- imma say 120 or so hp. put a cam in that biatch and you could see close to 130 or so cause of your headwork. ps. ditch that 2 3/4 piping and get 2 1/4, you need the backpressure</TD></TR></TABLE>
true. backpressure is your friend.
Re: (Houston Hatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Houston Hatchback »</TD></TR><TR><TD CLASS="quote">Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno Dyno V</TD></TR></TABLE>
hahahahahahahahhaahhahah omfg hahahha
your first post and you're givin me ****??? here's a for you...
it was intended to be a joke...you obviously cant comprehend any sort of humor good way yo make yourself look like a tool
it was intended to be a joke...you obviously cant comprehend any sort of humor good way yo make yourself look like a tool </TD></TR></TABLE>
calm down there little doggy, I think maybe he mis read you, and you should calm down because he obviously didnt get your joke..along with me as well. If you intended as a joke..put somthin like ...anyhoo..internet sucks at delivering humor the way we want it. ah well...
