Cable VS Hydraulic
Re: Cable VS Hydraulic (DelSolKid)
The pro's are: If you have a hydrolic tranny, and a hydrolic clutch, it works great.
The con's are: If you have a hydrolic tranny, and a cable clutch, it doesn't work.
Re: Cable VS Hydraulic (BauleyCivic)
NEVER EVER use a conversion kit!!!!!!
they suck.....just go with what you car is designed for and leave it at that
it is called the KISS method
Keep
It
Simple
Stupid
Keep
It
Simple
Stupid
one is old and one is new hydrolic is the new generation of trannys and i think newyer is better but then again if you cant afford it go with cable is cheaper but in the long run its all about hydro
With a hydro once your clutch is gone you must change it, With a cable via adjustment you can squeeze some more milage out of it. But as DIRTYSOL said deal with what you car came with, its not worth the effort to convert it. If you wanna pull more performance out of it, get a performance clutch and adjustments done.
ldanphanl
03-06-2005 08:50 PM
