cable and hydro tranny help :P !
I have a d16y7 1998 and the tranny is hydro but does a cable clutch fit in a hydro tranny ??
and are the spline the same cable or hyrdo ?? and are the clutch and flywheel the same size ?? thanks for all the info :) |
Re: cable and hydro tranny help :P !
Bump!
Need some answer soon a posible need to order :) |
idk about sohcs but I put a clutch out of a hydro gsr tranny into my ls cable tranny and had no probs
Ok thank need more info
Just order a clutch for your car.
Different spline count, it unfortunately doesn't work.
It will work as long as its not for a 88 or 89 Civic/CRX. The 88s have a different spline size. The 89's have a different clutch disc material size. 90-00 are the same and are interchangeable.
88 CRX (all) 190 mm clutch/21 splines 89 CRX (all) 200 mm clutch/20 splines 90-91 CRX (all) 212mm clutch/20 splines |
ok thanks
Like hondapartshero says it will fit ?:p me its hydro tranny and I want tu put a cable clutch in will it fit ?
Bump!
He answered your question what are you asking now?
I have a hydro tanny and i want to put o cable clutch in- why because the hydro clutch that i want dost ship to canada :p
