a/c and turbo?
a/c and turbo?
ok guys i did a search but cant find ****. my question is can i still have a/c if i go boost. im thinking t25 6 lbs of boost. oh yea and 6 lbs should be reliable right? i have 104,000 miles. and the o2 sensors can i use the one i have on my mani already. thanxx
Re: a/c and turbo? (HXvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXvtec »</TD></TR><TR><TD CLASS="quote"> 6 lbs should be reliable right? i have 104,000 miles. </TD></TR></TABLE>
Do a compression test, that will determine whether the engine can handle it. I'm not sure about a/c, but I remember a post the other day about how to remove a/c with the turbo already in, so I think its possible.
BTW - are you putting a turbo on an HX?
You can keep a/c depending on what type of manifold you use, but it is very possible. And 6lbs. should be good as long as it is tuned right. Also do a compression and leak down test before you boost, to make sure your engine is up to par, and try looking in the Forced Induction section. You'll have better luck there.
