A/c question
A/c question please help
I am thinking about buying a 92 cx hatch with a gsr motor in it. Would it be possible to put a/c in the car even thought the car never came with a/c. If so how difficult woudl it be. Thanks for any help.
Modified by duneracer69 at 7:51 PM 8/4/2006
Re: A/c question (duneracer69)
youll need a a/c bracket off a Del Sol Vtec. then everything will bolt up.
You can use a crv bracket as well, but you wont get to keep your power steering, so i hear.
yes you can install a/c into it. make sure you use a r134 system found in 94-95 civics. also read this write up i did earlier today about which bracket and compressor to use:
https://honda-tech.com/zerothread?id=1711739
Re: A/c question (philosofy1)
do you have to add anything to the inside of the car even though the car didnt come with a/c thanks for the help
yes, you will need a whole kit either from the dealer or from a salvage yard. the kit will contain the condensor, evaporator, a/c lines, dryer (basically). i purchased mine on ebay for $350 from a yard out in ohio, maybe you'll be just as lucky!
Re: A/c question please help (duneracer69)
Yes, you will need to modify the firewall? to accept the condensor, modify the core support/radiator mounts to take the evaporator, and install the vehical electrical components. Switches, relays, fuses, ECU leads, and some other things.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duneracer69 »</TD></TR><TR><TD CLASS="quote">does anybody no if this is a hard conversion to do.</TD></TR></TABLE>
no it is quite simple.
http://www.hondaautomotivepart....html
click on this site, it is an install instruction from a honda dealership.
