A/C only blows air on highest blower setting.
My A/C doesnt blow any air when its in " 1""2" or "3". The compressor would kick in, I would feel the slight engine bogging, but nothing would come out? How could I fix this myself? Its' a 94 del Sol VTEC, stock A/C setup * LOL* anyways, I searched a lot and couldn't seem to hit the right keywords if theres already a topic out there. . . any help would be great!
Re: A/C only blows air on highest blower setting. (Juan_Mitosis)
Its the switch....it's a 3 position resistor with the 4th position being direct 12v to the blower....if it blows on full, but nowhere else that tells you the resistor is shot.
no...its the blower resistor.
Drop the glove box and look at it...
Top-center #5
Held down by 2 screws and has 1 e- connector.
Since speed 4 has no resistor, it will always work when the others are out.
You might also want to double check your alternator output - if the voltage regulator is kicking out too much power it will blow these first, then start killing bulbs, then batteries...
Top-center #5
theheilious
04-13-2018 02:23 PM
