A/C Idler pulley bearing is whining and no refrigerant in A/C system
1999 Civic DX Sedan (D16Y7)
It's getting unbearably hot now (Summer) My car has a rust/gunmetallish paint job I suppose, and a ridiculously dark tint so it doesn't help with the heat. I just took out my A/C idler pulley today, finally, and the whining is all gone and so has my Freon for a few months; I want to get the aircon running ASAP though, so here are some questions: -Can I just buy the bearing itself and re-pack in the pulley? -If I get a new pulley / new bearing, would the chance of my aircon not losing it's 'cool' be gone, or do I have to test for leaks? (assuming the bad bearing is the reason for loss of freon over time somehow) -I'm ready if I can't get a bearing alone, to buy a DAYCO pulley on Rockauto for $30 shipped; anything better? (Contacted NAPA today and it costs $50+ just for the pulley; i'd rather not buy that) Here's a video of how it used to sound (swapped cluster from an Auto '98 CRV and was testing the tach, whining can be heard) http://www.youtube.com/watch?v=21E-XzxJXo4 |
Re: A/C Pulley Bearing (whining)
Are you talking about the idler pulley or the compressor pulley?
Oops; didn't specify ... idler pulley.
Re: A/C Idler pulley bearing is whining
Thread title edited.
Scout some local junk yards for a replacement idler pulley if money is the issue. |
Originally Posted by RonJ@HT
(Post 47344381)
Scout some local junk yards for a replacement idler pulley if money is the issue. I actually did some more bit of research.... stupid of me to find this out now. Size is (I hope): 70mm x 17mm x 20.5mm Guess i'll just look out for that bearing new locally and pack the pulley; if not, junk yard. Still wondering if the bearing affected my freon? Also; my car feels less held back now; there's a slight change in power unless it's just an audible illusion. |
Originally Posted by CO671
(Post 47344430)
Give more details. How do you know the A/C system leak out all of the refrigerant? |
(Post 47344453)
It's completely unrelated.
Re-assemble the system with new O rings, replace the receiver dryer, and place the system under a deep vacuum and check whether the vacuum holds overnight. If not, pinpoint the leak by adding a can of refrigerant containing oil and a leak detecting dye. The leak is located where dye appears.
