a/c help!?
a/c help!?
My 92 vx has a leak in the small hose in the front. i think i need to change the O ring in it cuz that is where it seemed to go wrong. where do i start, do i need to evacuate it? what about the R-12 charge? HELP! im in texas and its summer and its HOT!!
Re: a/c help!? (skizzlelizzle)
what ever you do, don't just take a filler hose with no can attached, put it on the low pressure side, empty it into the atmosphere, change the ring and refill the system, cuz thats illegal
Re: (spoonracer84eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonracer84eg »</TD></TR><TR><TD CLASS="quote">Unless you disconnected the compressor hoses then the o-ring is probably okay.</TD></TR></TABLE>
that isn't really true, if it isn't used for a long time the seals can dry up a little, thats why you should run it in the off season once and awhile
Re: (littlegreenb18)
i just got the car earlier this year and the a/c always made wierd noises in different rpms. from the clues and left over "juices" from the a/c it looks like a seal leak where the o ring is
Re: (skizzlelizzle)
Drain it or have it drained then disco the lines and replace the o-rings. It is illegal to drain it into the air fyi I personally dont give a **** how you do it.
ok a shop said they would do it all for 130 or if i did it myself they would do the charge for 60. does that sound good? i gotta wait til my next check tho.
hondaricegirlz
07-17-2004 06:52 PM
