A/C Compressor Idler Pulley problems
Okay so if anyone and i mean anyone can help it would be appreciated
so when i was putting on the A/C compressor idler pulley the first time after replacing the head gasket i tightened the bolt too tight on the idler pulley so that when i turned on the car it made a screeching noise because it was pinched to the clutch plate that ended up warping it (also if you can give me the technical term for that plate that looks like a dust cover for the bearings it goes over the bearings, its on the right outermost part of the idler pulley looks like a cover) anyway it warped and long story short it ended up shooting off of the pulley and taking the cover and nut with it on the highway
does anyone know how tight i am suppose to tighten the pulley to the bracket and if this mystery cover/plate is necessarily needed ?
thanks so much !!!
thanks so much !!!
Re: A/C Compressor Idler Pulley problems
thanks ron! will do, can you tell me if this will work?
http://cgi.ebay.com/ws/eBayISAPI.dll...#ht_500wt_1054
It should, but it's rusty and you didn't say you also need the compressor bracket. You could get just the idler pulley for much less money at a junk yard.
yeah the only problem is i need that clutch cover or whatever that thing is underneath the nut 9that im suppose to torque to 33 ft lbs0, they are ridiculously hard to find im looking all over the internet and they only sell the pulley by its self when i need the nut and the cover with the pulley
