a/c belt????
Re: a/c belt???? (speedaholic92)
What compressor are you running?
If you're running the civic compressor with the B18B like I am, get a belt that is 1" shorter then the one made for b18b.
You should be all set.
Re: a/c belt???? (94HybridEX)
i am running the civic compressor, how do i determine the inch shorter? just tell the counter guy to measure it? do you know for sure what car that belt was for?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedaholic92 »</TD></TR><TR><TD CLASS="quote">what belt will i need for my a/c compressor....i have an eg with B18B in it....can i use the civic belt, or do i need the integra belt......please help... </TD></TR></TABLE>
How long did it take for your struts in the front to go out? Cuz i have a friend who did an ls swap and his front struts are gone...it rides like has cut springs and his brake pedal is real mushy....j/c if this is what happens to everyone....
Re: a/c belt???? (99D16VTECCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99D16VTECCivic »</TD></TR><TR><TD CLASS="quote">
How long did it take for your struts in the front to go out? Cuz i have a friend who did an ls swap and his front struts are gone...it rides like has cut springs and his brake pedal is real mushy....j/c if this is what happens to everyone....</TD></TR></TABLE>I swapped struts long before I got a swap. I doubt the little weight difference in the motors would cause the struts to go out right away.
my struts had to be changed anyways, i had to put them in after the swap. i do not notice a mushy ride or anything. my brakes are fine.....
i found out that all i needed was an integra belt.....ARCHIVES ROCK!!!!!!!!!!
Re: (speedaholic92)
i found out that all i needed was an integra belt.....ARCHIVES ROCK!!!!!!!!!!</TD></TR></TABLE>I used a Teg belt, but I found that to be a bit too loose.
FijiOne
03-19-2018 07:05 AM
