Option fuse
Old 04-14-2017, 03:11 AM
Crocky's Avatar
Default Option fuse
I have a 1992 Honda Civic. Something is draining the battery. I have put a meter in the positive lead from the battery. I am measuring 1.5 amp draw with everything switched off, doors shut etc.
In the under hood fuse box I have removed a fuse one at a time. When I remove the option fuse the current draw drops to zero, but the car won't start!
Any ideas what the option fuse does?
Old 04-14-2017, 09:11 AM
Hysterically Calm
TomCat39's Avatar
Default Re: Option fuse
Can you provide a fuse number?
Under Dash:
Old 04-14-2017, 11:50 AM
mk378's Avatar
So, check if anything is plugged into option plug #1 on the left side of the underdash fuse box.
Old 04-17-2017, 10:31 PM
Oh look, I can change this
deschlong's Avatar
If it's #36 then that's a major fuse!! Start narrowing it down by pulling fuses in the under-dash fuse box. Your service manual (you'd better have one!) will show you all the things #36 is connected to.
Old 04-19-2017, 11:03 AM
O.G. triple O.G.
NVturbo's Avatar
You have a loose ground somewhere. They don't come loose, you or previous owner may have not bolted it down.
dhealey
Honda CR-V & Element
10
03-24-2018 03:47 AM
monsterCHILD
01-06-2011 04:28 PM
josh_db1
06-12-2010 02:46 PM
Hanmin
05-16-2008 02:17 AM
2LoW4FaThOeS
08-04-2002 10:40 PM
Quick Reply: Option fuse
