Burning a quart of oil a week with white smelly exhaust
Old 08-16-2011, 09:06 PM
m.glisson003's Avatar
Default Burning a quart of oil a week with white smelly exhaust
Have any ideas as to what my problem can be?
Im using a high mileage synthetic oil.
Old 08-16-2011, 09:20 PM
Wrona's Avatar
Default Re: Burning a quart of oil a week with white smelly exhaust
check foe symptoms of a blown headgasket
Old 08-17-2011, 01:21 PM
TheMechanic84's Avatar
check your coolant, if its milky its the HG, if not then you have a bigger problem....could be blown oil rings, Bad valve seals, or a clogged PVC pipe
Old 08-17-2011, 03:17 PM
apexi_rsx's Avatar
could also be a rear main seal leaking. running synthetic after using convention oil tends to leak past seals such as the rear main seal. 8 dollar gasket but a pain in the *** to replace.( removing the transmission and flywheel and clutch if its a 5 spd.) usually when the rear main seal goes it will drip on the exhaust and you will smell it. if its a 5spd it could have glazed the clutch and flywheel and need replaced as well or scuff and clean it really well)
Old 08-17-2011, 03:42 PM
The coolant is fine.
Any idea as to how long I can go driving it around and adding oil every week?
Im not experiencing a loss of power at all. And by the way it is a 5 speed.
Old 08-17-2011, 03:53 PM
motegicivic's Avatar
Do you see wet oil on the engine? if so where?
Check the oil pan and rear seal as well.
I have head gasket oil leak and been adding oil for a few years.
D16SiHatch's Avatar
as long as you keep adding oil it could very well run fine for quite some time. I wouldn't consider adding 4 quarts of oil every month very practical though.
Old 08-17-2011, 06:41 PM
williamZ's Avatar
Do a coolant system pressure test or a cylinder leak down test.
Old 08-18-2011, 07:42 AM
Depends if you get oil for 2 and change a quart, still cheaper than engine work.
Andrew99911
Honda Civic (2001 - 2005)
07-05-2017 11:46 AM
xprohx
04-30-2013 10:01 AM
chargingsnaild1
02-20-2013 11:11 AM
HondaFanatic708
04-29-2005 08:25 AM
b18c5T
01-31-2004 09:44 PM
Quick Reply: Burning a quart of oil a week with white smelly exhaust
