bulit motor need to know if it is ok to spray it or turbo
well i have a bulit b16 i need to know were is the safe area to boost or spray the guy who bulit it made it a high compreshine motor see is there some were i can find out i haven't see were i am at but only thang still stock motor wise in i need msd and camshaft le tme know plez thanks
Re: bulit motor need to know if it is ok to spray it or turbo (bulitassb1692)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bulitassb1692 »</TD></TR><TR><TD CLASS="quote">well i have a bulit b16 i need to know were is the safe area to boost or spray the guy who bulit it made it a high compreshine motor see is there some were i can find out i haven't see were i am at but only thang still stock motor wise in i need msd and camshaft le tme know plez thanks </TD></TR></TABLE>
what do you have in your motor.cant tell you if you dont tell us
Re: bulit motor need to know if it is ok to spray it or turbo (b18b1turbo)
i know is has high COMPRESSION
HIGH COMPRESSION
that is all i know about the motor i got it from a old guy that lost billing for it and the kid he did it for never came back to get it . i just want to know like a rang in COMPRESSION
HIGH COMPRESSION
that is all i know about the motor i got it from a old guy that lost billing for it and the kid he did it for never came back to get it . i just want to know like a rang in COMPRESSION </TD></TR></TABLE>
huh? High compression what?
You need to be more specific on the build of the motor, you bought the motor not knowing what's inside? You first need to know what the build consist of. Then from there you can maybe determine which route to go, spray or turbo.
HIGH COMPRESSION
Re: bulit motor need to know if it is ok to spray it or turbo (VTECth1s)
ya i did some old guy gave it away to me for 500 bucks and a kid wanted it build i know the only thang stock in side of the motor is camshaft i had a guy opean the head on it and he said it is port and every thang idk i think i jsut need to run a test on it when i get back
do u know wat the high u can spray at??? i just want too find out cuz i have some one with a zex kit and he olnly want 350 buck is for it and it a wet kit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bulitassb1692 »</TD></TR><TR><TD CLASS="quote">do u know wat the high u can spray at??? i just want too find out cuz i have some one with a zex kit and he olnly want 350 buck is for it and it a wet kit</TD></TR></TABLE>
Dude, stop posting. You sound like a expletiveing idiot. You have no grasp on your motor build or the english language in general. No one can help you when you spit out garbled up words without even forming a single sentence. Try to make actual sentences that somehow tell us what your build consists of.
No one can give you advice on a mystery motor.
Hurry and buy the zex kit, get it installed and start using it immediately, so you can break in the motor with the nitrous kit. Make sure its a 150 shot, so you can break in your built motor faster. And make sure you turn it on when you hit 5k rpm till redline.
Re: (highrev1987)
WOW, Its not "thang" its thing quiet trying to use internet Ebonics as its making you sound like a total tool. If you have no idea about your motor and its in your possession how do you think we would know anything about it? Try doing some research before you post stupid questions. Your more likely to get help if you came on here with a properly composed question stating the motor and compression test results. Then someone would most likely give you a compression ratio to the motor.
[B]??????????????????????????????????????????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bulitassb1692 »</TD></TR><TR><TD CLASS="quote">ya i did some old guy gave it away to me for 500 bucks and a kid wanted it build i know the only thang stock in side of the motor is camshaft i had a guy opean the head on it and he said it is port and every thang idk i think i jsut need to run a test on it when i get back </TD></TR></TABLE>
HIGH COMPRESSION
HIGH COMPRESSION
Only way to find out the actual compression is to pull the head,measure the stroke,measure the piston to deck height,figure out the dome volume, and CC the head...Other than that,you just be guessing...
A compression test wont tell you static compression either...
Re: (juda7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juda7 »</TD></TR><TR><TD CLASS="quote">TURBO FTW
http://www.youtube.com/watch?v=hM3jzlyNIpc</TD></TR></TABLE>
haha funny ****....
haha funny ****....
Re: (Dramier)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dramier »</TD></TR><TR><TD CLASS="quote">Twenty one years old, and this is what the public schools churn out now.
Jesus we are screwed.
x2
Just saying high compression doesn't help -- we must know what exactly is in the motor to help you out! Try spelling a little better too -- jesus...
x2
* B A N N E D *
What are you trying to ask or say?
Re: (ke98248)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 »</TD></TR><TR><TD CLASS="quote">Are you sure you've posted this link enough times? </TD></TR></TABLE>
Now I'm Good.
Now I'm Good.
Re: bulit motor need to know if it is ok to spray it or turbo (electron_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by electron_si »</TD></TR><TR><TD CLASS="quote">
No one can give you advice on a mystery motor. </TD></TR></TABLE>
x5,000
"ta ta today junior"
x5,000
