Built SOHC block
Built SOHC block
Lets start off with what is done to the block...
hot tanked block, water pump, oil pump, honed the block
-SRP 9.1:1 Pistons
-Eagle Rods
-Polished Crank
____________________________________________
And here is what its taking the place of...
the Engine Hoist rope had some problems and we got lucky it came out at all...
Yea!
I cleaned the engine bay with simple Green, not blang blang but much better...
Now to the good stuff
Runs Great, As of now having some problems but they should be fixed very soon. I will have some New pictures whenver i get around to washing the car again, but for now this will do...
984 miles left on break in
i love slowmo
-SRP 9.1:1 Pistons
-Eagle Rods
-Polished Crank
Yea!
i love slowmo
Re: Built SOHC block (P_t0wn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_t0wn »</TD></TR><TR><TD CLASS="quote">Apexi BB and some extras </TD></TR></TABLE>
what other mods are you running besides whats in the block? looks good so far..trying to convince a friend to build a sohc since he has the d16z6 laying around..
Nice job on the build. I want to know if you honed the cylinders yourself. If so, what kind of tool did you use and where did you get it? I'm also in the process of building my z6 bottom end.
Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">1.1 bar is like 16psi.
1 bar is 14.9psi</TD></TR></TABLE>
I thought 1 bar is 14.7 psi?
Unceasing Measure
Re: (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">
I thought 1 bar is 14.7 psi?</TD></TR></TABLE>
You are correct, my physics professor is wrong . 1 bar = 14.7psi.
Re: (MrDX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrDX »</TD></TR><TR><TD CLASS="quote">Question?... if using the right rods. Why notch the block?</TD></TR></TABLE>
Cause Eagles are too wide for the small 75mm bore of a D series. I had to notch my block for the Eagles to fit. Wider and stronger instead of skinny and weak to fit like the stock rods.
Re: (MrDX)
let me guess, H-beam rods?
the d-series block can't accept aftermarket h-beam rods, but stock style rods will fit fine
