bseries or hseries need help
im trying ot do a motor swap into a ekhatch.. i wanted to do a h2b or just a h22 with the tranny but some ppl are telling me that it would be kinda pointless and taht i should just go bseries. idk i seen a ekhatch with a h22 and it was quick. ppl are tellin me that cus of the weight is pointless need some help.. i will be boosting it in the long run only 10pounds.. thank you
I'm not Rick!
Re: bseries or hseries need help
h22s are not that much heavier. 30lbs isnt a big dif. h2b will just help it fit. i know that h22 motor and tranny you gotta bang alittle on the chassis on the tranny side to get it in. h22 have week cylinder walls though....dont boost too much. sleeve it then do 25lbs of boost youl be happy.
i dont want to boost that much just 10pounds its goign to be my daily driver onleast i boost more.. my goal will be close to 300hp if i can do more then ill do that..
I would say do the B swap because it will be easier. But if you want more power just do the H swap. I am not an expert but even though the H is heavier it will still haul ***** on a B....unless you get and ITR swap. Spend the money and get what you love.
I'm in kind-of the same boat as you OP. I would love to do the H swap, but a B just makes more sense on my budget.
Yes, the H22 is cheaper than a B18C (motor for motor), but you'll need to upgrade your cooling system a bit in order to keep the motor happy, which increases the cost of the job overall.
Also, with the H22 you will lose your power steering (which in a daily driver is a HUGE bonus).
But, like it has been said, build the car you want. If you want the torque and ***** of the H22, then by all means go for it.
yeah im going to go with the hswap at the end it will give me more power and ill be happyer.. what do you think i can make with all motor with it?
I'm not Rick!
its up to your wallet and your commitment. get some good cams and itbs. chip the ecu and get some bigger injectors im sure that will make you wet your pants at vtec
