broken lca/hub bolt wtf to do!!!
**** ok so today i went to install my blox lcas and i broke a bolt, the one closest to the rear drum, it snapped offat the head so i thought it would be ok to drive i took it for a drive and the wheel is leaning!!!!!! so i jacked it back up and put it were it needed to be and temp welded the hole with the stud, how can i get the broken bolt out!!!!!!!!
cut it off with a whizz wheel or burn it off with a torch. or cut the nut off the other end of the LCA an use a nut and bolt to replace it.
youll also need new lca bushings.
theres no set way to remove them, just get to cuttin. its all apart of the fun of auto mechanics!!!! i mean why pay a pro when you can do it yourself! lol. HAVE FUN
Re: (prettylew)
well i have a brand new set of blox lcas so i dont need the bushings so if i just start cutting i might be able to get them off...
if u got new lcas, just cut that bolt off, and if u can get the end out of the threaded hole on the car then ur good, if not, grind off that welded on nut piece that it threads on too and get a nut and bolt
Re: (prettylew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prettylew »</TD></TR><TR><TD CLASS="quote">if u got new lcas, just cut that bolt off, and if u can get the end out of the threaded hole on the car then ur good, if not, grind off that welded on nut piece that it threads on too and get a nut and bolt</TD></TR></TABLE>
thats the plan for thursday!!!! thanks guys and [freak] honda lca bolts haha
