break light on but e-brake down
well yep i was driving down the road and the brake light on the dash went on and my e-brake is ALL the way down. i put it up and down several times and it dosent go off. it went off a few days agao at random and now its back on.
whats wrong? i took out my center counsil to look at it and i see the wire and "button" type thing under the e-brake lever. it looks good and the wire seems connected.
what else should i look at?
Re: break light on but e-brake down (j-rome)
check your brakes maybe?? your pads might be getting low and the brake fluid would compensate for the play and you get a low fluid.
well i just took a look now and its 4/5 of the way down to the min mark.
ill pick up some brake fluid tommorow and a hood latch that i need at the honda dealer so while im down their ill get some fluid if its not to overly priced.
but ya ill let you kow how it goes when i fill it up all the way.
Re: (j-rome)
before you get the brake fluid, try to pop the front tires and check the pads for wear. i'm pretty sure that if your pedal didn't go down dramaticly one day i'm pretty sure you don't have a leak or anything.
ya now after i took off the resivor cover the light went off. their are wires comming from the cover so i would assume that would send the signal for that light.
all my bubls are good too.
but ya it needs a filling anyways so if it stays off then it was that but if it comes back on then ill be brining this thred back up.
but if anyone has other ideas keep giving them to me just incase.
adamcm16
04-10-2014 05:07 PM
Z7
10
08-06-2006 01:17 PM
Ehron
03-29-2003 06:05 PM
