Brakes are making a noise
Ok I took out my front brakes today to resurface them and i put them back on and some reason they felt wiggly and not tight. I put back on the calipers and bled them correctly. I put back on the front wheels and took it out for a spin. Now it makes a loud noise as if the discs are scratching the pads. But the breaks work good. Any idea on what I coulda did wrong in the process?
Re: Brakes are making a noise (siamturbo)
did u put in new pads after u resurfaced your rotors? if not that's prolly y
Re: Brakes are making a noise (98b16ex)
No their old pads. Should I start ordering some new ones right now?
new rotors and old pads = BIG NO NO
get some EBC pads, their not that expensive and well worth the money |
what you can do is take a flat slab of steel (some thing we have in our highschool shop) well its suppose to be almost perfectly flat, then lay san paper on top of it (i dont know which grit to use) then sand ur brake pad evenly.
