brakes effed up PLEASE HELP IM LOST!
i have all four integra ls disc brakes on my hatch, they locked up, front an back. i jacked up the car to try and spin them but there all stuck, i changed master cylinder bleed the brakes and there all still stuck. what else could make them all lock up? confusion
Re: (SOHC_4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_4dr »</TD></TR><TR><TD CLASS="quote"> or your proportioning valve went bad.</TD></TR></TABLE>
i was leaning towards this also
1 Post
Re: brakes effed up PLEASE HELP IM LOST! (allenbarnette)
Did the pushrod have an adjustment on it? You've got drag somewhere. Either the pushrod is engaging the primary piston, or you've got bad calipers, or your ABS is not bled out properly, if you have ABS...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allenbarnette »</TD></TR><TR><TD CLASS="quote">my brake lights cause of the lil bushing wore out, but i put a 10 mm in the whole so i fixed that</TD></TR></TABLE>What do you mean by this?
were the brakes working fine before?
there's a small chance that all your pistons may be seized (especially if you just got the setup from a wrecker where it sat for years).
jasonweaver88
06-29-2007 10:31 AM
