brakes...
Old 01-17-2006, 11:20 AM
unrefined7's Avatar
Default brakes...
level of difficulty: changing brake master cyclinder / proportion valve?
this is going into a 94 del sol S by the way. the parts are 91 ex civic sedan MC and 94 integra-RS prop. valve.
looks fairly simple to complete.
anybody know the hours of operation? advice?... this to do and not do etc... TiA -david
Old 01-17-2006, 12:30 PM
sohcvtec1995's Avatar
Default Re: brakes... (unrefined7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unrefined7 &raquo;</TD></TR><TR><TD CLASS="quote">level of difficulty: changing brake master cyclinder / proportion valve?
anybody know the hours of operation? advice?... this to do and not do etc... TiA -david</TD></TR></TABLE>
the brake MC should be a bolt ina s well as the PP valve. now the only problem you may run into is that you amy have to re bend some lines.. and thats not fun.. But do a search on this and there should be a write up or something to that nature explaning it..
Old 01-17-2006, 01:08 PM
unrefined7's Avatar
Default Re: brakes... (sohcvtec1995)
cannot find n e thing on it. it looks easy though. i just would like to know if i should look out for stuff
Old 01-17-2006, 01:21 PM
* B A N N E D *
Redline96LX's Avatar
you wont have to bend any brake lines, the del sol uses the same up and down prop valve as the 92-95 civic. master cylinder should bolt in, no problem. Only issue may be clearence. On my 96 civic, the prop valve on the firewall was very hard to get my brake line wrench in there, so you may need a few more tools. Id say if you do most of your car maintainence, it should be no problem.
Old 01-17-2006, 03:51 PM
ugrusa's Avatar
it's a simple job, but you willneed two people to bleed the system. you do not want air in those lines. .......by the way there should be no bending to those lines.
EgLuv94
Suspension & Brakes
10-03-2014 02:36 PM
Civic Racer X 7
07-02-2014 01:42 PM
raverx3m
Northwest (Sales)
02-14-2011 04:34 PM
newtype_civic
05-29-2007 04:31 PM
unrefined7
01-16-2006 02:01 PM
Quick Reply: brakes...
