Brake Tuck HELP ASAP IA 7 days away.
Ok so i need a quick respond brake setup
Car is 99 civic hatch dx
all new lines
30/30 prop valve
stock brake booster and master cylinder
JDM 5 LUG ITR brake setup
Problem i bled all the air out of the lines and i still dont have a real firm pedal
i dont knoe what else to do i kinda bled the MC itself and no air came out either am i using the wrong prop valve should i upgrade the MC i need to change things that are super necessary IA is only 7 days away i appreciate all the help thanks
all new lines
30/30 prop valve
1 Post
Re: Brake Tuck HELP ASAP IA 7 days away.
There's your problem.....stock brake booster and master cylinder .
Get the SI model booster and master. Should do the trick. I went through this with my EF when I went to a full DA brake swap. Had to get the matchin booster/master.
555R
09-23-2003 06:29 PM
