brake swap on ej6 sedan
Hello guys,
Tried to google my question but couldn't get any useful information, I'm pretty sure my ej6 sedan DX VP 2000 doesn't have ABS and it has 240mm front brake rotors, let me know if I'm wrong..... can I swap 262mm rotors instead without modifications?
Re: brake swap on ej6 sedan
I think only the EX came with an ABS option, but check under the hood for the ABS control module to verify.
You can just swap the larger rotors unfortunately. You will need to swap the knuckles for the EX/SI kind. Also, calipers, ( obviously rotors) and pads.
You will also want to swap the Master cylinder for the EX/SI. Leave the proportioning valve alone.
EDIT: Actually I think someone makes a bracket to use the larger rotors on the DX knuckle but you'd still need calipers/pads.
Might be cheaper just swap the knuckle.
