?brake question? need help asap
Old 05-12-2005, 01:56 PM
95civickid's Avatar
Default ?brake question? need help asap
when i drive my car and lets say im coming to a stop before ido the brakes go all the way to the floor. so today i was like f it i dont have anything to do + i know it has to get done so start bleeding the brakes 1. passenger rear everything good lots of pressure no air so i do this about 4 times next driver said rear this is where it gets bad have my boi slowly pump the peddle 3 time open the valve almost no brake fluid at all drips out. im like wtf so i must have re did this 25 times so then im like i will come back to this one close the valve move on 3. passenger side front my boi pump 3 times hold then the SAME thing as in the rear im like ahh **** no did this one about 25 times. moved on go to driver side front it goes perfect so im like wtf right now i douhgt its the mc im thinking proportion valve?+ now i know why the car pulled to the left when i hit the brakes. any advice. thanks in advance.
Old 05-12-2005, 02:00 PM
SOHC4life 96's Avatar
Default Re: ?brake question? need help asap (95civickid)
Go back and try bleeding those sides some more. And when you think you've done it enough, do it some more.
If that doesnt fix it then check your hard and soft lines going to those two brakes to make sure they are not leaking first. Then if they look good, try a different prop valve.
Old 05-12-2005, 02:07 PM
95civickid's Avatar
Default Re: ?brake question? need help asap (SOHC4life 96)
i mean this isnt the first time ive probably bleed the brakes like 20 different times in the past 6 months but it was never like this i mean ibleed the crap out of tese brakes i was probly out there for a good 45 min this time it shouldnt be ike this i mean my boi has a 94 and all we did when we changed his brakes was bleed each one 3 times. the pressure on mine should at least be getting stronger but all it does is barly drip out like there is no fluid in those lines
Old 05-12-2005, 02:43 PM
95civickid's Avatar
bump
Old 05-12-2005, 04:05 PM
95civickid's Avatar
Default Re: (95civickid)
come on guys need help bump
Old 05-12-2005, 06:19 PM
95civickid's Avatar
bump
Old 05-12-2005, 10:17 PM
95civickid's Avatar
bump
Old 05-12-2005, 11:12 PM
95civickid's Avatar
come on you guys are are always so helpful just want to know what the problem sounds like
aut0tek
05-01-2007 09:26 PM
nurvcom..
02-03-2006 06:30 PM
yusoslo
04-25-2003 10:29 AM
Lei Siew Long
09-30-2001 07:08 PM
LL
07-23-2001 04:07 PM
Quick Reply: ?brake question? need help asap
