Brake problems...
Brake problems...
So, I just swapped out my front brake pads, turns out the shop that had done the brakes previously decided they would only shim three of the pads and not the fourth. Anyways, one of the pads (inside right, I think) is now rubbing, causing the car to pull. What do I need to adjust to take care of this?
Re: Brake problems... (secondhandloser)
take the pads off and check them, cause you might have a seized caliper.. but you could also bleed it like he said.....CHECK THEM FIRST
Ek Forever y0!
Re: Brake problems... (4gencivicef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4gencivicef9 »</TD></TR><TR><TD CLASS="quote"> cause you might have a seized caliper.. but </TD></TR></TABLE>
Good point. Though improbable, it still happens occasionally.
Like those damn fan switch relays
EngineNoO9
Honda Motorcycles
22
05-25-2006 04:58 PM
