BRAKE PROBLEM..RF CALIPER WONT DISENGAGE
Here is whats going on...one day i had good brakes...did a clutch swap then as i was driving i smelt something burning and also felt the car moving slower. when i got home my right front wheel was egg frying hot...i changed the brake hose, the caliper, pads, master and slave cylinder..bled the brakes completely..still the caliper wont retract when the brake pedal is pressed or when i am rolling..i need to solve this problem and any help would do...thanks
CAR: 1993 4 DOOR EX-A HONDA CIVIC W/ABS 4 WHEEL DISCS |
Re: BRAKE PROBLEM..RF CALIPER WONT DISENGAGE
sticky piston, disassemble and clean and lube it.
Check for a seized caliper slide pin.
Originally Posted by NOTUNINGNONADA
(Post 46883237)
."i changed the brake hose, the caliper, pads, master and slave cylinder..bled the brakes completely..still the caliper wont retract when the brake pedal is pressed or when i am rolling"
You may have a clogged brake line running to that caliper.
Originally Posted by RonJ@HT
(Post 46884574)
someone told me that possibly the abs sensor for that wheel went bad the magnetic pulsating signal that the ring send thru the sensor to the pump is making it unaware to retrack the fluid to that side...:shrug: |
almost sounds like you had one issue, a sticking caliper?? and by throwing so many parts at the problem you have accidentally introduced a "new" bad part????
at this point i would diagnose the problem instead of spending any more money. get the brake to lock up start at the caliper loosen the bleeder up. did the caliper unlock? if the caliper loosened up (and fluid came squirting out as opposed to a dribble) then you still have pressure in the line somewhere. if the caliper is still locked you have a bad caliper. if there was pressure in the line when you cracked the bleeder your problem is further up the line. lock the brake up again and open up the brake line right where the rubber line meets the steel line. did the caliper loosen up ? if it did not then you have a bad rubber line if it did then you need to proceed to the next junction i doubt the prop valve is an issue but you never know. work your way up to the master cylinder in this fashion . if you make it all the way to the master cylinder and still have an issue the test here is a little bit different lock up the brakes and then loosen the bolts that hold the master to the booster. did the caliper loosen? if it did then you have a master with an internal issue, the wrong master or your push rod is too long. if it stayed locked after you loosened the master cylinder retaining nuts loosen the line that goes to that caliper. if it frees up then you have a bad master. sorry for the long post, hope this helps |
1. try adjusting the push rod and if that fails then
2. replace your bake booster 3. thank me i would say ask me how i know, but i think you know how i know |
What will happen if i disconnect all power going to the ABS MODULE??
