Brake problem
Brake problem
recently when i press on the brakes the pedal slowly travels to the floor. what do u think could be the problem..Master Cylinder?...and if it is how much do those cost my car is a 94 civic ex coupe with 4 wheel disc and abs
Re: Brake problem (2DoorBandit)
well first is your fluid all proper level?
and check all your brakes and check for any leaks......
if ya cannt see any then try bleeding all your brakes out totaly! ya want clean fluid pumpen thru.... if the problem still thier id say replace the master...
Re: Brake problem (addiction2bass)
fluid is fine ill take a look at my brakes soon and bleed them
there is no leaks cause the fluid stay the same
the soL that could
10
05-21-2006 09:50 AM
Jose-aka-Pedro
05-18-2006 03:25 PM
