Brake Pad Clips...
My new pads didnt come with the lil retainer clips on the brake pads.. they are the right pads though.. Now my brakes kinda squal when i decellerate in gear... take it outta gear and it gets realllly faint... same as when i tap brakes, it goes completely away... Anyho, is this a possibility as to why my brakes squeak
Re: Brake Pad Clips... (JDM_SOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_SOHC »</TD></TR><TR><TD CLASS="quote">My new pads didnt come with the lil retainer clips on the brake pads.. they are the right pads though.. Now my brakes kinda squal when i decellerate in gear... take it outta gear and it gets realllly faint... same as when i tap brakes, it goes completely away... Anyho, is this a possibility as to why my brakes squeak</TD></TR></TABLE>
I think so. Those clips are suppost to keep the pad in place and some have anti-squeaking shim's or something like that. I am pretty sure you need those on, but I could be wrong. Also, did you spread disc-quiet stuff all over the back sides of the brake pad (where the piston touches the pad)? |
Yeah I think ur missing the brake pad shim..thats what prevents brake squeal. You can get brake shims from autozone and stuff for cheap. And yeah, like Bond said, use the disc quiet junk and put it on the back of the pad where the piston hits the pad. Once you get the shim in, it should stop squeaking. https://honda-tech.com/forums/images/smilies/emthup.gif
Re: (jeffk182)
The problem you have isn't from the clips. Clean and lube the slides, also lube the back of the pad and then place the shims on em. Lube the section of the pads that come into contact with the caliper bracket also. This should resolve the issue you have at hand.
Re: (Hybrid93Eg)
Well check this out.... I went to take off my wheel to get to brake pads and lug nuts just unscrewed by hand almost they were so loose... What the f$%@ makes it do that..!! Lug nuts aren't supposed to just come off with ease... What makes'm come loose from being twerked <Torqued> on...
Re: (JDM_SOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_SOHC »</TD></TR><TR><TD CLASS="quote">Well check this out.... I went to take off my wheel to get to brake pads and lug nuts just unscrewed by hand almost they were so loose... What the f$%@ makes it do that..!! Lug nuts aren't supposed to just come off with ease... What makes'm come loose from being twerked <Torqued> on... </TD></TR></TABLE>
They were not properly torque to 80 ftlbs. |
Re: (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg »</TD></TR><TR><TD CLASS="quote">
They were not properly torque to 80 ftlbs.</TD></TR></TABLE> ^^^^Yup https://honda-tech.com/forums/images/smilies/emthup.gif . In some cases really bad wheel vibration has made lug nuts become loose, but never enough to be done by hand. Did you forget to tighten them? |
