BRAKE LIGHTS don't work
Ok my brake lights just stopped working out of no where the other day all the other lights work except my brake lights. I need them fixed asap
What i did so far
1. Checked changed bulbs
2. Checked fuses
3. Replaced brake switch on brake pedal
Its a 95 civic cx hatchback with a k20 swap
I dont know what else to do. The only thing i can think of is me and a friend took off the tint on the windows and maybe the water got to the wires but why would that only mess up my brake lights and no other lights. I need help asap i need brake lights
Thanks in advance
What i did so far
2. Checked fuses
Thanks in advance
Re: BRAKE LIGHTS don't work
Did you even take a look at your wires?
How did you "check" your fuses? Looking at them? Or actually using a tester? Maybe try actually replacing them. With the correct amperage fuse.
Unplug the harness and check for green on the metal. If yes then clean them with the correct cleaner or be cheap like me and just cut and splice. I don't recommend that though.
classic69
12-22-2005 09:09 PM
FullMetalJacket
12
04-29-2003 10:07 AM
