Brake lights
Re: Brake lights (NA EG6)
i just had this problem, the thing with mine was that the break bulbs i had in were the wrong ones and were put in backwards. i know that doesnt sound possible but it is. i just went and bout new civic brake bulbs from autozone and now they work fine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA EG6 »</TD></TR><TR><TD CLASS="quote">What number bulbs are they </TD></TR></TABLE>
it says 2057 on the box mine came in
mine say 1157 is there the correct bulb, and my 3rd brake light doesnt come on so i dont think they all whent out at the same time with out a blown fuse
ya, def a switch, fuse, or wire....sorry, it's kind of hard to trace after that...you have to follow wires, look for breaks..
EDIT:
Wait, do they come on when u turn ur headlights on?
EDIT:
bust out a light tester, pull the brake light bulb and test the conector for power..... if your geting power then its not a fuse problem
just bad bulbs..........
ive had it happen before believe it or not! in my truck when i bought it all the rear lights seemed to be blown! even 3rd brake, and even the 2 cargo lights!
it was insain!
just bust out your test tight again :D
and if youve done any kind of modifications lately check those! could be a wire crushed, cut, shorted out....
it was insain!
ok something is really wrong because i tested it the way you said and on the driverside tail light one of the connectors just got hot and the tester almost got stuck
Storm13
09-14-2010 07:07 PM
