Brake light problem
Brake light problem
hey guys, need help, i have a 99 civic ex, couple weeks back to of my wires that plug in to the brake switch got burned, i had no horn and no brakes light. i took out the dash and fix the bad wires in the harnse and attach them back. the horn and the lights work now, but the driver side indicator light comes on every time i mash the brakes.
i check the wires and make sure nothing is touching or grounging out. Anyone have had this problem or any ideas on what else i can check to solve this problem?
Re: Brake light problem
if you have a voltage meter, read the wires for voltage. if you come across one with no volts, that is you shorted wire or your disconnected wire.
It's the turn signal indicator and my in-dash cd player light up also when i mash the brakes, i was just under the dash not finding anything but something i grounding out but what could it be i am going to try the volt meter but i have to learn how to use it lol, so but RonJ i will attempt ur method and see what i can find.
stellium
01-15-2010 10:23 AM
