brake fluid change and bleed questions
LX Civic '02
How much brake fluid would I need to buy?
How many pumps does it take before the the MC empties when bleeding?
What size clear vynle (sp?) tubing fit the bleed screw?
* B A N N E D *
Re: brake fluid change and bleed questions (huyvu90)
i would rather suggest to suck out the fluids out of the resevoir with a turkey baster... and replace it with better and higher grade of fluid... and do it every week and you will end up cycling the fluids and replacing enough to the point its 95% new fluids
