brake conversion help. yes i searched.
heres my problem. i have a 92 4 door civic dx. my entire setup is fugged up, according to pepboys. i have inspection in 8 days. the told me i need to replace my mc right rear wheel cylinder, both front calipers, along with the regular maintenece crap. and quoted me at $875. so i decided to attempt a swap/upgrade. i wnated to know what is the easiest/cheapest way to do this. i was thinking rear disc off of an ex, 4040 prop valve, mc off a 91 civic ex 4door.
what else do i need, and should i do this or go for integra rear and front. please help i onoly have 7 days left.
Re: brake conversion help. yes i searched. (djsire)
well your question has been answered ill help you out
you want to get the REAR DISK's off of any civic or integra that has them make sure you get the e-brake line too, its different then drums. also get the brake lines.
the front disks you should try a 94-00 integra ls,rs,gs,gsr. you want the whole arm assembly with the rotor,caliper and brake line
i don't have a 40/40 prop valve, because i RR and see alot of people that have that done locking up the rear's i have never done and braking is fine
you are correct you do want the 91 ex MC
Re: brake conversion help. yes i searched. (H.A.R.T b16a1crx)
not to thread jack, but is it just the 4 dr ex's that have discs in the back? cause i have an ex coupe w/ rear drums
Agguhnitus
10
02-14-2012 02:04 PM
NoLeftTurn
04-25-2008 12:19 PM
nefariousyellow
10-17-2007 01:48 PM
