Civic runs rough
Civic runs rough
My 95 1.5l 16 valve runs terrible. Ive replaced the spark plugs, wires, cap, rotor and coil. The car idles ok but misfires when accelerated. If I pull the spark plug wires off the plugs I noticed that cylinder four doesnt spark when held to the valve cover. Cylinder 3 sparks a little. And cylinders 1+2 cant even be removed from the spark plugs with the engine running or the engine stalls. The only thing I can think of would be the igniter in the distributor but wouldnt this just cause a "no-start" condition? Any help appreciated.
Re: Civic runs rough
If you are not getting cyl #4 spark, check the dist cap and wires. Sounds like you got a carbon track in the cap which is sending the spark somewhere else.
its not the coil, since if it was bad it would give you no spark.
Noo_Ish_mee
06-27-2016 02:44 PM
ex_ricer
08-14-2008 02:14 PM
homer_eps
12
04-09-2008 08:09 PM
